Teodorian
Objektivet levereras nu och omdömena börjar ges. Här är ett:
http://www.amazon.com/Nikon-85mm-1-4.../ref=pd_cp_p_2
"To be clear, by my eye, there's not a huge difference in image quality, as the older lens was already excellent on all counts. The updated version is maybe slightly sharper in the corners on an FX body, colors seem perhaps a bit more vivid, and it seems a bit less prone to flare when you point it directly at a bright light source. It focuses a few inches closer than its predecessor and weighs maybe an ounce or two more. Still, it's not like one is "bad" and the other "good" - just slightly different, and not at all a dramatic difference for most users.
To me, where the compelling value comes from is the new AFS focusing setup, making autofocus nearly instant and incredibly accurate. Thanks to the wide f/1.4 aperture, you always get a bright image, and on both my D3 and D300, focus is blindingly fast and dead-on accurate. This was my only real gripe with the previous lens, and I found myself often either missing shots because of the slow autofocus, or I'd spend a lot of energy manually focusing instead of composing the exact shot I wanted. Now, with the new 85mm f/1.4G, I get fantastic image quality, plus much better and faster handling - and to me, that makes it worthwhile."
