Äntligen Nikon D800
- Trådstartare phool
Teodorian
Motsvarar väl ca 16mp på APS-C.....så pixelstorlek lik D7000.
15,2 MP i DX-läget.
Teodorian
Stämmer uppgifterna med 6 bilder/sekund med batteripack så är det ta mig f... otroligt och 4 bilder utan
En lossless 14-bit NEF borde ligga på runt 52,7 MB. 4 bps ger 210,8 MB/s och 6 bps ger 316,2 MB/s. 6 bps i DX-läget ger 138,5 MB/s.
Przemek
phool
Min vän, det där är gamla nyheter =)
Przemek
Hoppsan någon hann visst före =)
macrobild
The new Nikon D800 surpasses all expectations with its 36.3 megapixel resolution ensures maximum fidelity and unsurpassed
The new release of the Nipponese company offers unparalleled features to please all demanding professional photography, videographers and filmmakers.
Sao Paulo, February 6, 2012
Nikon introduces its long-awaited release, the HD-SLR D800, which offers resolution never seen before, amazing picture quality and valuable video resources, still optimized for professional multimedia photographers and videographers. With unparalleled balance between precision and functionality, the Nikon D800 brings innovations such as the CMOS sensor 36.3 megapixel FX-format, 91,000 pixel RGB sensor, advanced Scene Recognition System and many other new features.
Exceptional Image Quality
The new 36.3 megapixel CMOS sensor (7360 x 4912 resolution) and FX format (35.9 x 24mm) is the largest in terms of resolution so far developed by Nikon, and come meet nikonzeiros numerous requests from around the world. It is ideal for situations where you can not compromise the fidelity, such as weddings, photo studio and record landscapes. A resolution of this magnitude gives the photographer the ability to portray even the smallest details with stunning clarity. Every aspect of the sensor of this model was designed to ensure clear images in low light, so it has enhanced features like OLPF converter and a 14 bit A / D to minimize the noise around the picture.
The D800 lives up to Nikon’s reputation of being the sovereign ability to capture in low light thanks to the standard range of ISO 100-6400, expandable to 50 (Lo-1) and 25600 (Hi-2), which helps create gradient amazing colors when shooting JPEG or RAW.
All these image data are directed to a channel of 16 bits for maximum performance. Photographers can also take advantage of the lenses in FX format lenses for more options and increased focal range (1.5X), while still maintaining the clarity and detail in high resolution of 15.3 megapixels (4800×3200).
The D800 has an advanced Scene Recognition System with its array of colors (3D Color Matrix Meter III), which provides precise measurement in the most challenging lighting conditions. At the heart of this system is the innovative RGB sensor that analyzes each scene meticulously, recognizes factors such as light and bright and then compares all the data using the unique database of 30,000 images from Nikon. This new sensor still has the ability to detect faces with high accuracy even when shooting through viewfinder. The Color Matrix Meter also prioritizes the faces detected, allowing the right exposure even when the subject is backlit.
Novelty is also the exclusive image processing engine Nikon’s EXPEED 3, which controls the entire system and is the catalyst behind the responsiveness of the camera’s auto focus and performance. The new Nikon image processing engine is capable of processing huge amounts of data, with perfect color and tone perfect. 3 The EXPEED also contributes to energy efficiency, allowing the user to use the camera for longer.
Featured in the new and improved white balance system of this model that more accurately recognizes both the sources of natural light and artificial ones, and gives the user the option to retain the warmth of ambient lighting.
Users can also capture a greater dynamic range with the HDR function and enjoy the benefits of Active D-Lighting for balanced exposures even in backlit scenes. In addition, the camera offers a dedicated button for quick access to Nikon’s Picture Controls to adjust the parameters of photo and video in real time, such as color, sharpness and saturation.
True Cinema Experience
The Nikon D800 is a compact and lightweight which is ideal for the production environment. Its features are very practical and functional usable by both filmmakers in the field and in the studio or filmmakers. Filmmakers have the option of multiple resolutions and frame ranges, including Full HD 1080 and HD 720 30/24p to 60p. By using the method of data compression B-Frame, the user can record video in H.264 / MPEG-4 AVC up to 29:59 minutes per clip. The optimized CMOS sensor reads the image data on rates incredibly quick results almost instantly.
The D800 also allows videographers to keep the resolution high definition (1080p) regardless of the selected scene mode. Users can also compose and easily check critical focus for HD LCD monitor 3.2 “and 921 000 pixels with reinforced fabric, automatic control of brightness and wide viewing Anglo.
For professionals, it is important to have a camera that has digital recorders and external monitors. With the D800 is possible to transmit an uncompressed HD signal directly off the camera for an HDMI output (8 bit, 4:2:2). This signal can be transmitted to a display, digital recording device or routed through a monitor, eliminating the need for multiple connections. The image can also be viewed simultaneously on the LCD screen and an external display screen while excluding the state data of the camera for streaming media.
The D800 also includes features to enhance the audio quality, as a specific output for headphones used to monitor the audio levels during recording, which can be adjusted within 30 steps. Have the onboard microphone can be adjusted with up to 20 steps of sensitivity for the faithful reproduction of sound. To complete the recording can be configured to be activated via the shutter button.
Shutter speed and performance with amazing accuracy
The autofocus system Advanced Multi-Cam 3500 AF is the next generation of the proven 51-point AF system Nikon. The fully customizable system offers users the ability to capture fast moving subjects in focus and accurately track, or select a single AF point with absolute precision in detail. The focus system uses 15 sensors of the type AF Crusaders for accuracy and the system also emphasizes human faces even when the viewfinder is used. The D800 also employs 9 cross-type sensors fully functional when used with compatible NIKKOR lenses and teleconverters aperture f / 8 or smaller.
For maximum versatility in different situations, users can also select multiple AF modes, including normal, expanded area and tracking of faces and objects / people, even the optical viewfinder.
Ready to shoot in less than 0012 seconds, the Nikon D800 can capture files in FX mode and resolution up to 4 fps, or up to 6 fps with DX mode with the optional battery pack MB-D12 battery and compatible. To further improve the speed of the camera and the overall workflow, the D800 uses the new standard USB 3.0 for fast transfer.
Format and operability
The structure of the Nikon D800 is designed magnesium alloy for maximum durability and reliability. The camera body is closed and sealed with gaskets to resist dust, moisture and also to electromagnetic interference. You can easily picture of the composition through the viewfinder of course, which offers 100% coverage of the scene.
The shutter was tested to withstand 200,000 cycles, ensuring maximum durability, while the sensor cleaning is made by the vibration of OLPF. The self-diagnostic shutter unit also includes a mirror balancer to minimize the residual impact of the “bounce”, improving the AF and zoom viewing time. Furthermore, the display is coated with a new finish protection thermal which serves to resist to overheating during prolonged use. For storage, the D800 has dual card slot for CF and SD cards, offering the user the possibility of recording up when a card is full, recording RAW / JPEG, separately, and the added option of recording still pictures to and video card to another. For recording and transfers at high speed, data can be recorded on the latest UDMA-7 and the cards SDXC/UHS-1.
The D800 also features built-in flash, and is compatible with the acclaimed Creative Lighting System Nikon, including the Command Mode for embedded control Speedlights wirelessly.
Przemek
Jag har varit på pressträffar både för instegskameror och Coolpixar. En gång var huvudnumret den (då) nyöppnade Nikonstore ...
Vem vet, Nikon kanske tänker börja tillverka skrivare och konkurrera med Canon på allvar :-D
Nikon coolprint, jodå låter ju bra =)
macrobild
Nikon är så fiffiga att de läser ut signalen mer än en gång och kan därmed få från en12 bitars A/d få flera steg än vad A/D i sig tillåter vid en utläsning , se D3x
I kameran enligt texten ovan så sitter det en 14Bitars A/D , gör de en liknande utläsning som den i d3x så skulle det inte förvåna mig, men Joakim kan mer om detta
The_SuedeII
Törs man förvänta sig 15 ev DR?
Definitivt inte på pixelnivå. 14Ev, antagligen precis under (typ 13-komma-högt) om allt följer indikationerna.
Det man ska tänka på är att man sällan använder ett 36MP orginal till en 36MP färdig bild, utan oftare då samplas det ner till kanske A3 * 250dpi (12MP) för en vältryckt spread i en tidning med högre tryck-kvalitet, en lagom stor förstoring eller dylikt.
Den tekniska DR-siffran ökar då med roten av skalfaktorn i MP, den praktiska (verkligt användbara) DR ökar med roten av skalfaktorn i procent bildmått. I en 9MP slutpresentation kan man alltså tillgodogöra sig någonstans mellan en halv och en hel Ev mer i DR (än vad pixelnivå-DR ligger på), om sensorn är fri från mönsterformat brus.
Teodorian
Mer info om D800:
http://mansurovs.com/nikon-d800-announcement
Här anges en buffer på enbart 10 NEF i 36 MP och 20-22 i DX-läget vilket låter lågt. Det är ganska uppenbart att Nikon "strypt" D800 för att inte inkräkta på D4 och en kommande D400.
Teodorian
Osäkert om priset. Här är senaste budet:
http://nikonrumors.com/2012/02/06/nikon-d800e-priced-at-3300-unconfirmed.aspx/#comments
Teodorian
Mer info om D800:
Å andra sidan så klarar D7000 just 10 st NEF i 14-bit NEF och klarar D800 20 st 14-bit NEF i DX-läget är det klart bättre för samma MP och bps, ett bättre AF-system mm samt en gnutta bättre bildkvalitet.
Splanky
pet
- 21 K
- 7 K
