UV filter till 70/200f4
- Trådstartare Bagheera
BrommaAnders
Välj det filter du tycker passar dig.
" * The Tiffen Haze-1 is best. It's a neutral filter so color balance is unaffected.
* Next is the Tiffen 812. Good UV blocking if you also want a warming filter
* The Hoya 81B is very similar to the Tiffen 812.
* The Hoya UV filter comes next, neutral, but with 2 stops of UV blocking.
* The B+W KR1.5 gives about 1.5 stops of UV blocking with slight warming.
* The Tiffen polarizer gives less than a stop of UV blocking, but that's not why you use a polarizer!
* The B+W and Hoya 1B aren't very good UV blockers. The 1B is slightly warming
* The three "generics" and the Tiffen UV protector are pretty useless for blocking UV, though they may make fine, neutral, lens protectors."
http://www.photo.net/equipment/filters/
Anders
Anders
Erik Bergqvist
Anvander (till just den gluggen) B+W 67 010 UV-haze 1X.
Tycker B+W kanns battre samt ar lattare att fa rent an motsvarande Hoya. Bildmassigt marker jag ingen skillnad.
/Erik
/Erik
- 4 K
- 7 K
