Canon 40D kommer
Status
http://www.geheugenkaart.be/english/store/viewitem.asp?idproduct=8981440
10.1 MP CMOS sensor
5fps, 30 JPEG image burst
Integrated Cleaning System
2.5 Inch LCD with 230K pixels and 160º viewing angle
Picture Style image processing
Spot metering & 9-point AF
DIGIC II processor with 0.2 sec start up
Digital Photo Professional software
Magnesium alloy body
Compatible with all EF/EF-S lenses and EX Speedlite flashes
Including powerpack and accessories
English or German manual
Connectivity
CMOS sensor
An 10.1 Megapixel CMOS sensor provides the sensitivity needed for clean, detailed images with fine colour gradation. Large sensor pixels allow for wide dynamic range and reduced noise at higher ISO speeds. The 22.5 x 15mm sensor size adds an effective 1.6x increase to the focal length of EF lenses, extending reach at the telephoto end.
5 fps shooting
The camera delivers fast 5 fps shooting for continuous bursts of up to 30 large JPEG images (11 in RAW). A new 3 fps shooting mode provides greater control for variable-speed sequences.
Large LCD
Illuminated by 6 LEDs, the bright 2.5 Inch 230K pixel LCD is viewable from 85° in almost all directions.
Picture Style
Picture Style pre-sets provide easy control over image processing parameters. Each style offers a different colour response - similar to the way film types are changed to achieve different effects. Sharpness, contrast, colour tone and saturation are adjustable within each pre-set.
Spot metering
Spot metering allows you to base the optimal exposure value on a concentrated spot (3.5%) in the scene - useful in high-contrast scenes where precise metering control is required.
High precision 9-point wide-area AF
Select from one of nine fixed focusing points across the scene for fast, accurate focusing even with off-centre subjects and 'rule-of-thirds' compositions.
DIGIC II
DIGIC II renders colours with precision and accuracy. Fast and efficient, DIGIC II prolongs battery life* and delivers instant 0.15 second start up time.
The Digital Photo Professional software permits high-speed processing of lossless RAW images.
A compact magnesium alloy body provides durability while keeping the camera's weight down to 700 grams.
EF lenses and accessories
The EOS 40D is compatible with over 60 EF lenses (including the EF-S Series) and all EX Series Speedlite flash units. The E-TTL II flash algorithm passes key shooting data from compatible EF lenses - such as focal length, point of focus and distance information - to the Speedlites for consistently accurate flash exposures. Untethered shooting is possible with the optional Wireless File Transmitter WFT-E1.
Connectivity
Video Out allows reviewing on a TV screen. Connect with USB 2.0 Hi-speed for fast data transfers.
*750 shots per battery charge, according to CIPA standard testing.
Lieden.se skrev:
Läs på dpreview.com. Där finns rykten så det räcker och blir över. Alltifrån en 32MP 1Ds till inga Canonkameror alls i år. Take your pick ;-).
Mvh, Ulf
Lite mer spännande blir det iofs om man väljer att tro på rykten om nya kameror istället för rykten om inga kameror alls.
Finns många rykten om en uppdaterad 1D Mk II med olika angivna upplösningar som 10 MB, 12 MB och 16 MB. Samtliga med ff.
Läste senast i dag om någon som tror det blir uppdateringar av EF 28/1.8 och EF 85/1.8. Jag är dock skeptisk till de ryktena. (Däremot tror jag på en ny 24-70/2.8 med IS).
Men Canon kommer med nya kameror och det är nästan lika sant som om Sverige får väder.
10.1 MP CMOS sensor
Connectivity
Har inte koll på 30Ds egenskaper men vad är det som är nytt i 40D i detta fall? 2 extra MP? Digic II? "Antidust"? Är det värt så mycket uppmärksamhet?
Vänta två dagar så slipper ni fundera och/eller oroa er helt i onödan...
Jag tror att tiden är förbi då vi kunde se stora hopp i den teknologiska kamerautvecklingen. Titta på utvecklingen mellan 20D till 30D och 350D till 400D, det är små finesser som förändras. Jag tycker att specen är rimlig, dvs. det kommer inte att ske så stor förändring mellan 30D till 40D.
Sensmoral; köp det du behöver nu! Dröm inte om kommande kameror.
Låter ungefär som steget 350D -> 400D. Är nog ganska troligt. 30D:n är för ung för att det skall komma några revolutinära nyheter i nästa modell (om den kommer redan nu).
Nä, de verkliga nyhterna lär nog komma i 1D-serien.
Eller vänta tills 40d kommit o köp 30d då för en billigare penning.
Risken är att förväntningarna inte uppfylls och att vi snopet sitter här med "bara" de förväntade uppgraderingarna. Så har det ju varit förr. Jag tänker på 20D -> 30D.
CMOS sensor
An 10.1 Megapixel CMOS sensor provides the sensitivity needed for clean, detailed images with fine colour gradation. Large sensor pixels allow for wide dynamic range and reduced noise at higher ISO speeds.........
Hmmm... undrar om det inte finns en stor nyhet i den formuleringen. D v s ..large sensor pixels... Om de lyckats att göra den effektiva pixelytan större kanske man lyckas med bättre DR och lägre brus på högt ISO. Är lite osäker men har för mig att den effektiva ytan idag har varit mindre än 50% av själva pixelytan.
Skall bli spännande, vare sig det blir nyheter den 22 februari kl 9 som någon har sagt, eller 8 mars när PMA drar igång :)
SixBySix skrev:
CMOS sensor
Det är ju en mycket intressant spekulation... men som sagt vi vet om 2 dagar....
Fast förutom att man bytt ut 8,2 mot 10,1 är hela den texten ord för ord tagen från 30D så åtminstone DET är nog ingen indikation på någon teknikrevolution.
Det enda man gjort är att man kombinerat specifikationerna för 30D och 400D och hamnar alltså på samma kamera som alla andra som spekulerat ända sedan 400D presenterades för ett halvår sedan.
Det är möjligt att 30D:s efterföljare (när den nu kommer) får just de specarna men den sidan är inte mer bevis för det än alla andra amatörgissare.
Undrar varför länken till Canons hemsida inte visar den nya modellen....................Går det att manipulera skärmdumpar............Nä det kan man väl inte göra..........
Status
