Sony's Full-Circle 360° Camera Module
bjanha
Ny, jävligt cool pryl från Sony:
"Until now, taking a 360° panorama with a normal lens has required taking multiple shots while rotating the camera slowly and then combining ("stitching") those shots together to form the panorama. In contrast, the 360° full-circle lens allows the full 360° surroundings of the camera to be imaged at the same time with a single lens.
Sony has now developed a camera module that uses this 360° full-circle lens, and is releasing as commercial products both a camera module that uses a 380K-pixel, 30 fps CCD that outputs a ring-shaped image as a composite video signal as well as a high-resolution camera module that uses a 1.28 MP, 7.5 fps CCD with a built-in panorama expansion processing function."
- Images a full 360 degrees in one operation
- Supports pan, tilt, and zoom without mechanism
- Focus adjustment for distance not required
- Images the whole surround area with a small convex lens
http://www.sony.net/Products/SC-HP/cx_news/vol34/featuring2.html
/bjanha
