Photoshop - prestandatest
Status
16,6 sek
Jag fick 16,6 sek på följamde system:
(Det står windows NT, men det är Win 7, 64-bitars)
Testade igen med 12,6 sek som resultat.
Adobe Photoshop Version: 11.0.1 (11.0.1x20090218 [20090218.r.523 2009/02/18:02:00:00 cutoff; r branch]) X64
Operating System: Windows NT
Version: 6.1
System architecture: Intel CPU Family:6, Model:14, Stepping:5 with MMX, SSE Integer, SSE FP, SSE2
Physical processor count: 2
Logical processor count: 4
Processor speed: 2664 MHz
Video Card Vendor: NVIDIA Corporation
Video Card Renderer: GeForce GTS 250/PCI/SSE2
OpenGL Drawing: Enabled.
Video Card: NVIDIA GeForce GTS 250
Video Mode: 1920 x 1200 x 4294967296 colors
Video Card Driver: nvd3dumx.dll,nvwgf2umx.dll,nvwgf2umx.dll,nvd3dum,nvwgf2um,nvwgf2um
Driver Version: 8.16.11.9107
Built-in memory: 8187 MB
Free memory: 5796 MB
Memory available to Photoshop: 7207 MB
Memory used by Photoshop: 60 %
Image cache levels: 4
Serial number: 92628918362284851165
Application folder: C:\Program Files\Adobe\Adobe Photoshop CS4 (64 Bit)\
Temporary file path: C:\Users\JRGEN~1\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
C:\, 279,4G, 234,0G free
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS4 (64 Bit)\Plug-ins\
Additional Plug-ins folder: not set
9,7 sec
Kör med CS3 och Windows 7 Home Premium
Sony Corporation Modell VGN-FW51MF_H
Total mängd systemminne 6,00 GB RAM
64-bitars operativsystem
Antal processorkärnor 2
Typ av grafikkort ATI Mobility Radeon HD 4650
Total mängd tillgängligt grafikminne 3823 MB
Dedikerat grafikminne 1024 MB Dedikerat systemminne
Bildskärmsupplösning 1920x1080
DirectX-version DirectX 10
Kanns som att min 3 och ett halvt ar gamla Mac Pro fortfarande hanger med ratt bra, aven om jag bara kor CS3 och 32 bitar.
Adobe Photoshop Version: 10.0.1 (10.0.1x20071012 [20071012.r.1644 2007/10/12:09:30:00 cutoff; r branch])
Operating System: Mac OS 10.5.8
System architecture: Intel CPU Family:6, Model:15, Stepping:6 with MMX, SSE Integer, SSE FP, SSE2
Physical processor count: 4
Processor speed: 3221 MHz
Built-in memory: 12288 MB
Free memory: 2239 MB
Memory available to Photoshop: 3072 MB
Memory used by Photoshop: 100 %
Image cache levels: 6
Serial number: 10450218702984391201
Application folder: Harddrive RAID 1:Applications:Adobe Photoshop CS3:
Scratch volume(s):
Harddrive RAID 1, 931.2G, 225.1G free
Primary Plug-ins folder: Harddrive RAID 1:Applications:Adobe Photoshop CS3:plug-Ins:
Additional Plug-ins folder: Harddrive RAID 1:nik CEP 2.0 IE:
    19.5 KB · Visningar: 661
Manuellt klockad tid: 8,5s
Jag har PSE8 men det verkar vara samma filter. Alla inställningar heter som OP angav för Photoshop.
Min tid är verklig tid (+- 0,4s skulle jag säga) mätt med mekanisk analog klocka som alltså inte steppar sekund för sekund. Man kan alltså se sekundvisarens läge mellan helsekundstrecken.
Timingen i PSE8 kan variera mellan 16,7s och 30s så den slår nog ihop tid från de olika processorkärnorna.
Dator
Windows 7 Pro 64bit
Moderkort GA-P55A-UD4
Proc. Core i7 860
Minne 8GB Kingstonvalueram 1333MHz
Hårdisk Ssamsung SpinPoint F3 500GB
Grafikkort Powercolor HD 4670 512MB
Verkar som om man fått ihop en rätt OK burk :)
Ps. Va' bra att man hitta den här tråden. Nu fick jag lära mig mer om PSE8 och vad som t ex gömde sig bakom den lilla pilen nere till höger.
Tack för det :)
17,6 då :)
Det ar val den tiden som alla andra har redovisat?
Det har du rätt i. Jag läste förstås om någon som uppmärksammat att externt klockad tid var betydligt kortare
Vi får nog ändra min tid till 17,6s så att även jag håller mig till reglerna :)
Jag stängde ner och startade om PSE8 och öppnade bilden på nytt för säkerhets skull.
mera lek
Vill man göra det lätt att få ett korrekt resultat så kör man först filtret, backar sedan tillbaka med Ctrl + Z och sedan trycker man Ctrl + F så gör man om de senaste filtret, man slipper få med den tid som filterfönstret är öppet och man slipper göra ett macro...
Får 10s med intel q8200 4 gig ram
Med den metoden får jag 8,3s
Det blir också samma tid varje gång
Och så upptäckte jag att jag tidigare körde min bild från USBminne :)
7,3 sekunder
Pentium I7 4 kärnor (visar 8 i taskmanagern). 6 Gig minne.
Filtret verkar använda alla kärnor.
/Tomas
Intressant att Mac Pro (2007) fortfarande står
sig mycket väl med 5,9 sek.
Har uppenbarligen inte hänt mycket på
processorfronten sen dess.
Jerry
9,1 sec
Körde med macro i CS3, och har uppgraderat till 8 gb i ramminne.
Windows 7 Home Premium, 64 bitars
Total mängd systemminne 8,00 GB RAM
    15.1 KB · Visningar: 540
10s med en i5 2,67GHz på ett Asus P7P55D Evo med 4GB RAM. Hyfsad förbätttring från min gamla E4300 på 1,8GHz som tog nästan en minut på sig! =)
Testade PS CS3 mot CS4.
Körde testet 5 gånger.
Blev ingen större skillnad mellan de båda.
CS3 41,2 sek 39,2 sek 33,4 sek 32,5 sek 32,2
CS4 44,9 sek 34,8 sek 35,6 sek 32,0 sek 32,6
Dator: Macbook pro
Processor: 2,4 GHz Intel Core 2 Duo
Minne: 4 GB 667 Mhz DDR2 SDRAM
Från trådens början... 2005, 2 minuter.
Känns väldigt avlägset.
Allt är relativt, sitter ju fortfarande med säkerhetskopiering som tar hela natten.
Jag tycker ändå att det borde hänt mer, särskilt nu sen core i5 och i7 kom. Jag får ca 11sek med min oklockade 2,4Ghz Quadcore och 4gb ganska billigt ram-minne.
Status
