Kit
Står det nårga priser på den? Jag mailde ett företag i USA som gör kit för detta, de har hyffsade priser. Men lägger man till alla extrakostnader so mdet innebär att få hit det till Sverige så blir det rätt dyrt ändå, det bästa vore nog om man kände någon som kunde ta med det hit. Klipper in svaret nedan.
Hello,
You can purchase the timer and accessories by following BUY NOW link. (the product is only available through the website)
Following are the most typical components for high speed photography:
1. UPT_KIT1A/B/C is a general purpose photographic timer. It can activate camera shutter or flash in response to a trigger with a set delay.
"A" version has a built in microphone, "B" and "C" version use an external microphone (standard sensitivity microphone is included).
2. UPT_OS1 or UPT_OS2. OS1 is a light sensor that requires a separate RED laser pointer (you can buy them in office supplies store). The optical sensor is just a simple photo-transistor. Whenever the beam is interrupted the timer is triggered. For example for water drop photography, you can use it to detect a falling drop and create a delay so that you fire the flash/activate the shutter when it hits the surface of water. OS2 is slot sensor and operates on similar method as OS1, except is does not require a separate laser. The advantage of OS1 is that it can be used with large or small objects.
3. UPT_HS1 hot shoe adapter used to connect the timer with a flash. The flash needs to operate in manual mode with center pin triggering.
Typical darkroom sequence to capture a falling drop is as follows:
- open camera shutter in your camera (in bulb). You can do this manually or the timer can automate camera control.
- release a drop
- optical sensor detects a drop (UPT_OS2 or UPT_OS1)
- create a delay with the timer as needed (for example it takes approx 0.45sec for an object to fall 1m)
- after a set delay the timer will activate the flash to make the exposure
- close the shutter
The user guide for version UPT_KIT1A/B can be downloaded from
http://www.universaltimer.com/UPT_UserGuide_RevA4.pdf (in PDF format).
The user guide for version UPT_KIT1C can be downloaded from
http://www.universaltimer.com/UPT_UserGuide_RevC.pdf (in PDF format).
The shipping price charged through the website (in the range from $18 to $24) covers an air mail parcel service to Sweden with an estimated delivery time of 6 to 12 business days (the time is not guaranteed, some delays may occur as with any mail). There is no tracking option for this. The post office includes approx. $90USD insurance per package. Depending on purchase, the shipment may be split into two or more separate packages. Please note that the price does not include any duties or taxes that you may need to pay in Sweden. Courier service is available at an extra charge.
Please let me know if you have any questions.
Thank you,
Ark Biel
Universal Timer Ltd.
Toronto, Ontario
email. mailto:
[email protected]
URI.
