Om man tittar på ett flödesshema över ett minolta objektiv så ser man där att i chippet kan man lagra AF-offset, frågan är ju varför?
Sensor, mattskivan och AF-sensorn borde ju alla fokusera rätt om det är lika långt till dom, enda skillnade jag kan se är att ljuset som går till AF-sensorn måste passera igenom en extra glasruta.
Hur var det innan AF fanns? Kunde ett objektiv fokusera fel då med, även om alla andra objektiv fokuserde rätt på samma kamera-hus?
Klippte detta från Free patens online,
http://www.freepatentsonline.com/5517475.html
Optical information processing apparatus in which the offset of a tracking error signal is corrected in accordance with a relationship stored in a memory, in response to a position detection output signal.
Document Type and Number:United States Patent 5517475
citat:
Abstract:An optical information processing apparatus includes an optical head for irradiating a light beam onto an optical recording medium, an objective lens, mounted on the optical head, for condensing the light beam onto the recording medium, a photodetector for receiving a light beam from the recording medium and for generating a tracking error signal indicative of a positional deviation between a light beam irradiated position and a track, a tracking actuator for moving the objective lens in a direction intersecting tracks of the recording medium, a tracking controller for driving the tracking actuator in accordance with the tracking error signal so as to correct the positional deviation, a position detector for detecting a relative position of the objective lens with respect to the optical head in the direction intersecting the tracks, a measuring device for measuring a relationship between an offset of the tracking error signal and a position of the objective lens from the tracking error signal and an output of the position detector, a memory for storing the relationship measured by the measuring device and a correction device for correcting the offset of the tracking error signal in accordance with the stored relationship, in response to the position detector output signal.
Killen som skrivit detta borde off the record gå en skrivkurs eller för att få den lite mer lättläst. Många bisatser är det.
Vad jag förstår så jämförs offset-värdet, som funkar som ett referensvärde, med det värde systemets styrsystemet fått fram. Diffar det så korrigeras diffen med hjälp av offset-värdet. I detta fall talar vi inte direkt om ett helt slutet system som svänger in mot ett perfekt fokus av sig själv. Istället får vi ett system som först ställer objektivet i ett läge reglersytemet kommit fram till. Först efter det så överstyr ett korrektionsvärde (offsetvärdet) som man tagit fram genom exv. en praktiskt test som visat hur mycket man måste kompensera för att systemet verkligen ska vara fokuserat. Det är detta offset-värde då som kan användas för att tvinga AF-systemet att göra en finjustering efter att det själv tror att det hittat fokus.
Det borde inte vara någon skillnad vare sig motorn sitter i objektivet eller kamerahuset. Problemet är ju detsamma men det skulle kunna vara så att man i äldre objektiv (kardandrivna) förlitat sig helt på logiken i kamerahustet och att eventuella justeringar i objektiven gjorts med schims istället. Det skulle kunna funka båda två vägarna. Vad jag vet så sa killarna på LP-Foto att det finns inget att justera i gamla Minolta-objektiv men jag ska fråga Werner (som är den som gör de mesta av reparationerna) när han är på jobbet i morgon om han har tid. Annars är väl problemet nu att det inte finns speciellt många kvar nu som kan finlira med gamla Minolta-objektiv. Jag gissar att där har vi väl en selling point för svindyra Sony-objektiv.
