Nu är det klart med Sigma 24mm f/1,4 Art
gunnargren
Pressrelease
Sigma Corporation of America Introduces New 24mm F1.4 DG HSM Art Lens at CP+ Imaging Show
Latest Global Vision Art lens offers highest-quality optical performance in its class
YOKOHAMA, Japan — February 10, 2015 – Sigma Corporation of America, a leading researcher, developer, manufacturer and service provider of some of the world's most impressive lines of lenses, cameras and flashes, today announced the new Sigma 24mm F1.4 DG HSM Art lens, the ninth Global Vision lens to join the company’s iconic Art line-up. The announcement comes at the start of the CP+ Camera and Photo Imaging Show 2015, which begins on Feb. 12 in Yokohama, Japan.
The much anticipated 24mm F1.4 Art wide angle lens is designed for full-frame DSLRs, and when used on digital cameras with an APS-C size image sensor, it effectively becomes a 38mm. The lens is ideal for capturing a variety of photography subjects, including cityscapes, mountain ranges, astrophotography and weddings and is great for videography work as well. The 24mm also excels at indoor photography in low illumination thanks to the combination of exceptional focal plane sharpness, and gorgeous bokeh rendered by nine rounded aperture blades. The lens achieves a maximum magnification of 1:5.3 with a minimum focusing distance of 9.8 inches. The 24mm incorporates both "F" Low Dispersion (FLD) glass and Special Low Dispersion (SLD) glass in a design of 15 elements in 11 groups to minimize chromatic aberration of magnification especially in the edge of the image field. Moreover, the optimized power layout includes aspherical elements that are positioned in the rear of the lens for improved wide open performance. This helps to ensure minimal distortion through the correction of axial chromatic aberration and sagittal coma flare. The new lens element design also delivers excellent peripheral brightness.
“The Sigma Art lenses are recognized by photographers for world-class performance, and the new 24mm F1.4 DG HSM will be a significant contribution to our selection of fast aperture prime lenses which is quickly becoming a strong force in the industry” said Mark Amir-Hamzeh, president of Sigma Corporation of America. “Sigma is redefining the expectations of fast-aperture full-frame prime lens performance, especially wide-open, and the results the 24mm F1.4 will deliver will be up to the exacting standards set by the 35mm F1.4 DG HSM and 50mm F1.4 DG HSM .”
Other updates to this lens include a new full-time manual focusing mechanism that switches to manual focusing, simply by rotating the focus ring, even when AF is being used, first introduced on the 50mm Art. This allows the photographer to make focus adjustments quickly and easily. As with all new lenses under the Global Vision categories, every 24mm will be tested using Sigma’s own MTF measuring system, “A1,” in the company’s factory in Japan.
Other lenses in the Art line include 35mm F1.4 DG HSM, 30mm F1.4 DC HSM, 18-35mm F1.8 DC HSM, 24-105mm F4 DG OS HSM,50mm F1.4 DG HSM, 19mm F2.8 DN, 30mm F2.8 DN and 60mm F2.8 DN.
The 24mm F1.4 is compatible with Sigma’s USB dock, allowing photographers to update the lens’ firmware and change focus parameters as well as manual focus over-ride using Sigma's Optimization Pro software. It is also compatible with Sigma’s Mount Conversion Service. The lens will be available in Canon, Nikon and Sigma mounts, and timing, pricing and availability will be announced at a later date.
En mycket rolig nyhet för mig personligen, då jag funderar starkt på att skaffa ett 24mm/1,4-objektiv framöver.
Så jag ser fram emot att få se testresultat från denna rackare!
Ser lovande ut!
Spännande!
Jag har i flera månader kikat på de andra fasta F1,4-objektiven i denna serie, framför allt 50/1,4. Än så länge har det dock inte blivit något köp, och jag tvekar fortfarande efter att ha läst om alla problem med autofokus. Det är synd att inga tester tar upp detta på djupet! Hoppas att Sigma åtminstone delvis fixat detta. Firmware hit och dit, USB-docka, micro-adjust... Hur svårt kan det vara att kalibrera varje objektiv innan det lämnar fabriken?
Just 24mm är en brännvidd som jag ofta använder i olika sammanhang. Om Sigma har lyckats så bra som de skriver med att eliminera abberationer redan på stor bländare så blir objektivet ännu mer användbart i mina händer.
Ser fram emot tester!
Jag har fått för mig att autofokusproblemen främst drabbat Canon. Så kör du Nikon behöver du kanske inte vara så orolig.
En datapunkt är inte värd så mycket, men autofokusen på min 50/1,4A (för Nikon) fungerar ungefär så bra som jag tycker är rimligt att förvänta sig.
Verkar stämma! Har själv 35/1.4 HSM Art till Nikon och det sätter fokus spot-on på full öppning i princip alltid. Undantag: Vid disigt gråväder i exempelvis en januarieftermiddag och längre avstånd kan det missa om det inte finns tillräcklig kontrast där jag sätter fokus.
Men vilken f/1.4- glugg gör inte det?
Har bekanta som använder den med EF-fattning på 5DMkIII som haft vissa problem.
Nu går det att lägga en per-order på BH Photo i New York och priset ligger på 849$. Vad ska vi tro priset hamnar på i Sverige, 8500-9000?
1 självklart köp om det är lika skapt som 35 & 50 art!
Varit sugen på 35'an men tycker den är för smal, 24 bör passa mig perfekt så nu väntar man bara på lite olika tester...
mvh jens
autofokus
Spännande!
Ser fram emot tester![/QUOTE
Jag har ett 50 mm 1.4 Sigma art och använde USB docka för att ställa in det till min5d markIII. Justerade på 4 olika avstånd ,tog en halvtimme, och efter der fungerar det helt klockrent och objektivet ger mycket bra bild. Bilden upplevs som helt skarp över hela ytan på 1.4. Den upplevs lika skarp och fri från kromatisk abberation som 24 mm TS-E II , dessutom distorsionsfri. Det är mer än värt besväret! Hälsar till Byskan !!
Tackar! Det var ett gott betyg för Sigma, och jag tror dig. De foton jag sett har också den där extra lystern som jag gillar. Jag hoppas dock på att Canon kommer med en ny 50/1,4 II snart. Varför inte med bildstabilisering som den underbara 35/2,0 IS USM? Om det nu går att göra på ett så ljusstarkt objektiv? Precis som med det objektivet skulle jag också önska supersnabb och exakt AF och att objektivet är mindre och lättare så att det kan vara med hela tiden. Man får helt enkelt drömma vidare ett tag. :)
Åter till ämnet så ska det bli väldigt intressant att se hur Sigma 24/1,4 Art presterar!
Presterar riktigt bra, gillar omfånget 24mm (haft canon 24 1.4 II förut) tycker det är bra autofokus det jag använt än så länge.
överlag otroligt bra jobbat av sigma, älskar deras nya serier ART / SPORT osv..
