Minne för exponeringsdata?
Mikael Westerberg 10D
Hej !
Går och funderar på en Canon 10D eller 300D till hösten. Är det någon som vet om någon av dessa kameror kan lagra exponeringsdata om varje bild, tex bländare, slutare, mm? Jag vet att det går på den traditionella kameran Eos 1V.
/ Micke
Exempel från en D60 (D30 är likadan)
File: CRW_2976.jpg
File size: 2420KB
Image Serial Number: 329-2976
Camera Model: Canon EOS D60
Camera serial number: 0630502097
Firmware: Firmware Version 1.0.4
Owner: Roine Karlsson
Date/Time: 2003:08:23 10:58:05
Shutter speed: 1/1000 sec
Aperture: 3,5
Exposure mode: Av
Flash: Off
Metering mode: Center-weighted average
Drive mode: Continuous
ISO: 100
Lens: 70,0 to 200,0 mm
Focal length: 130,0mm
Subject distance: 5,12 m
AF mode: One-shot AF
Focus point:
Image size: 3072 x 2048
Rotation: none
Image quality: Raw
White balance: Auto
Saturation: Normal
Sharpness: Normal
Contrast: Normal
Custom Functions:
CFn 4: Tv/Av and exposure level: 1/3 stop
CFn 5: AF-assist beam/Flash firing: Does not emit/Fires
CFn 10: Auto reduction of fill flash: Disabled
CFn 12: SET button function when shooting: Change ISO speed​
Från en Digital Ixus:
File: img_1943.jpg
File size: 685KB
Image Serial Number: 119-1943
Camera Model: Canon DIGITAL IXUS
Date/Time: 2000:09:09 11:27:34
Shutter speed: 1/125 sec
Aperture: 7,1
Exposure mode: Program
Flash: Off
Drive mode: Single frame shooting
Focal length: 5,0mm
Subject distance: 0,137 m
Macro focus: On
AF mode: AI Servo AF
Focus point:
Image size: 1600 x 1200
Rotation: none
Image quality: Fine
White balance: Auto​
Ungefär den här informationen går att få fram om varje bild:
File: IMG_5497.JPG
File size: 2,295KB
Image Serial Number: 154-5497
Camera Model: Canon EOS 10D
Camera serial number: 0230102497
Firmware: Firmware Version 1.0.1
Owner: Magnus Lundkvist
Date/Time: 2003:08:23 15:57:18
Shutter speed: 1/80 sec
Aperture: 4.5
Exposure mode: Tv
Exposure compensation: -1/3
Flash: External E-TTL High speed sync
Flash exposure compensation: -2/3
Metering mode: Evaluative
ISO: 400
Lens: 24.0 to 85.0 mm
Focal length: 24.0mm
Subject distance: 0.291 m
Image quality: Fine
White balance: Auto
Color space: sRGB
Saturation: Normal
Sharpness: Low
Contrast: High
Tone: Normal
Custom Functions:
CFn 6: Tv/Av and exposure level: 1/3 stop
CFn 8: RAW+JPEG mode: large, fine
Det enda som saknas är GPS info så man vet var man tog bilden ;-)
/Magnus
Roine, använder du din sigma glugg 24-70 mycket? Tänkte köpa ett Tamron 28-70 f2,8 till en 300D, tror du det är ett klokt beslut? Blir inte så mycket vidvinkel, men tänkte kanske köpa någon fast sen. Eller hur är tamrons 19-35 glugg på en digitalare?
Tamrons 19-35:a är väl sådär... Lite väl högljud af. Hyffsat skarp om man bländar ner nåt steg. Ingen vinjettering att tala om, iaf inte på 10D.
Som Cosina/Soligor ungefär, fast med interfokusering och bättre byggkänsla.
Ett bra budgetval mao.
Jag har 24-70/2.8 på som standardobjektiv. Den använder jag mest av allt och är mycket nöjd.
Har en Canon 28-80/2.8-4.0L som mest ligger o skräpar för varje mm betyder en hel del samt att det är 2.8 i ljusstyrka hela vägen.
Har en reseuppsättnig då jag åker på semester där jag tar med mig 28-70/2.8-4L och 35-350L då de har samma filtergänga.
Mina bilder från Rhodos i år är tagna mest med 24-70/2.8 o jag är nöjd.
Har även en Sigma 14mm, men den använder jag inte så mycket då det blir extremt, utan då man måste ta inomhus i tex kurslokaler osv.
Roine
Hur gör man för att utvinna all denna info?
Kan inte hitta något i Photoshop eller nån annan stans.
Tack
