PFH
Pentax K-3 II Specs List:
24MP CMOS sensor (low-pass-less)
Improved Antimoare function
Effects of shutter 4.5 stage of camera shake correction
The high-resolution image by pixel shifting. Low noise excellent color reproduction and detail.
86000 pixel RGB metering sensor
ISO range 100-51200
Video Full HD 60fps / 30fps
Dust and water proof. 92 places sealing of
Chassis stainless. The body is magnesium alloy
Flash not equipped
GPS built-in
Built-in electronic compass. Can be displayed the direction on the LCD monitor
ASTROTRACER
AF module SAFOX 11. AF point 27 points (25 points cross type)
Accuracy improvement of continuous AF
Continuous shooting 8.3 frames / sec. 60 sheets in JPEG, 23 shots at RAW
Image processing engine PRIME III
Finder penta prism. 100% field of view, magnification 0.95x
LCD monitor 3.2 inches, 1.037 million dot
Dual SD card slot
Allows remote operation from the smartphone-tablet · PC with the optional Flu Card
USB 3.0 and HDMI terminal
Synchro Terminal
The battery D-LI90
The size of 131.5 x 102.5 x 77.5
Weight 785g
Hämtat på cameraegg.org
ISO range 100-51200
Flash not equipped
GPS built-in
ASTROTRACER
Dual SD card slot
Synchro Terminal
The battery D-LI90
Weight 785g
