Eos 3d
f.billqvist
sökte runder på nätet vet inte om detta är sant
canon Eos 3D och bild så klart lite lurt
här är lite kamera info
Introducing the revolutionary EOS 3D.
Built from the ground up to represent the new face of digital imaging the EOS 3D will represent a breakthrough in high performance yet affordable photography. Featuring an elegant yet supremely functional design it takes the best of Canon's previous designs and enhances the experience even further. A high performance AF system featuring 27pt of which 11 are x-type down to f/4 while and the centre point is cross-type to f/5.6 and allows AF down to f/11. The AI servo performance has been significantly improved too, exceeding that of the 1D Mk II.
Also Canon proudly brings ECF to the digital era and is greatly enhanced in performance over that found in the Elan 7NE.
However, the true revolution lies in the heart of the camera. Packing an amazing 13.3MP into an APS-H sized sensor the images are processed by a new DIGIC III engine. The next generation DIGIC III Image Processor builds on the legendary abilities of the digic II with double the processing power necessary to deliver unprecedented levels of resolution, speed and dynamic range. Despite the EOS 3D having smaller pixels than the EOS 5D, the DIGIC III provides even greater DR, more accurate colour rendition improved WB and lower noise. ISO 50 and 3200 are now part of the standard ISO settings and ISO 25 and 6400 are now included as an expanded option. Also it further reduces power consumption allowing class leading battery performance.
Thanks to DIGIC III the EOS 3D also boasts an impressive burst rate of 6fps for 18 shots in RAW and 40 in jpg.
In addition the body adds several sealing gaskets to the all magnesium shell allowing for operation in more extreme environments. A new evaluative algorithm allows more accurate metering in extreme lighting and can even correctly expose subjects like snow. Also a 2.4% spot meter allows for precise metering of any part of the scene. The viewfinder shows an impressive 98% of the scene both horizontally and vertically. Also for the first time Canon will be employing 2.75" OLED display screen, offering superior resolution, brightness and power consumption to LCD screens and having markedly better performance in bright daylight
Oh.. boy.. den där är gaaaammmmaaaal En tillplattad EOS 1 med hmm D2x?
underrede om jag inte minns fel.
Jag startar klockan.. Gissningsvis 2000 visningar innan midnatt ;)
har du sett denna bild tidigare jeppe ?
inte jag om det är sant så verkar det super bra kamera i allafall
Gammal nyhet, men visst ser den läcker ut :)
Det är nog en dröm som aldrig kommer att slå in.
/kent
Och jag hoppas att allt det där var sant, förutom aps-h..
Nåja, vi lär väl få se vad det lider, har ändå inga pengar att handla för för tillfället.
*HOPPAS* *HOPPAS*
