Sony DCS-W1
- Trådstartare callring
FouFoto
Men då köper du väl DSC-W3?
Utdrag från www.photosig.com:
Conclusion - Pros
* Very Good resolution
* Low noise with some noise reduction
* Good macro performance
* Excellent build quality, good ergonomics
* Proper hand grip
* Excellent auto focus speed
* Very fast shot to shot times (just over 1 sec)
* Excellent write speed (up to 4 MB/sec)
* Good battery life
* Optional screw mounting lens adapter
* Very large 2.5" LCD with anti-reflective coating
* Multiple media support (MS Pro & CF)
* External flash support via Hot-shoe
* Fast USB 2.0 transfers
* Combined AC Adapter / Battery charger
Conclusion - Cons
* Tendency to use small apertures
* Design fault with jog dial & program shift
* About a third of a stop less sensitive than indicated
* Limited image parameter adjustment
* Poorly fitting flash unit
* Lens retracts too quickly in play mode
* Sharpening halo artifacts at default setting
Conclusion - Pros
* Proper hand grip
* Good battery life
Conclusion - Cons
- 21 K
