Lyssnar Pentax??
paddmannen
Skickade några förslag till modifieringar av firmwaren till K10D till pentax international. Va ju trevligt att få svar...
Nu kan man ju bara hoppas att japanerna i pentax head quarters lyssnar.
Vad tror ni? Lyssnar tillverkare till sina kunder egentligen?
(Om pentax kommer med en ny firmware om tre veckor med alla de här grejjorna tillrättade...ja då jävlar...)
Dear Sir/Madam,
Thanks for taking the time to state your praise and concerns for pentax.
Thank you for contacting Pentax.
If you are in need of further assistance, please respond to this email or call
our technical support center at 800-877-0155.
Sincerely,
Timothy Fig
Pentax Imaging Technical Support
Your Email:
Your engineers have done well with the new K10D. I
certainly hope that pentax will be back with the big players again and Iam quite
happy that I chose the pentax system.
However, there are some minor issues with the camera - and almost all ofthem can
be corrected with a new firmware. I don't know if you have thehabit of listening
to the users of your products, but if you do it wouldbe nice if you could
transmit this mail to your engineers back in japan..
Firmware modifications:
1. Let the user be able to use the flash for AF assist WITHOUT firing theflash.
As it is now the flash is always fired once it's up. If you are
focussing when it's dark but do not want to use the flash you have to
press the focus lock button first, then lower the flash, then take the
picture...
2. Let the user be able to give the raw button any other function, for
example white balance or mirror lockup.
3. To let the user choose when and how he wants to use shake reduction andmirror
lockup. As it is now the only way to have mirror lockup is to usethe 2s delay
and with the SR automatically disconnected. So the camera cannot cope with the
following situations:
-You handhold the camera and use the 2s delay to avoid movements
associated with pushing the shutter button. Here you very much would liketo have
the SR on. But it's "off" by default...
-You want to pinpoint the exact moment to push the shutter button and
still use mirror lock up. As it is now you have to anticipate the momentwhen you
want to take the photo by two seconds. It should be possible tomaintain the
mirror in locked position and then chose the exact moment totake the picture.
This is especially coherent if you use a cable release.
4. When you press the raw button you are only shooting raw until you viewa photo
on the screen, then it switches back to jpeg mode. Therefore itoften happens
that you believe that you shoot raw, but in reality the
camera has already gone back to jpeg. It would be better if you were
shooting raw as long as the camera is "ON".
best regards
Jag såg en interview med en ansvarig på pentax och frågan gick på varför dom redan hade haft 3 uppgraderinger tilll k10d, svaret gick på att dom lyssnade extra noga på sina kunder, pentax har gått utt och sagt att dom vill vara dett kameraföretag som har bästa förhållande till sina kunder, än så länge funkar dett, så bara vänta till 1.3 och du kommer nog att se att dom lyssnar.
Jag tror det är mycket få som vill ta bilder på fri hand med 2sek fördröjning... det är en funktion att använda med stativ. Det skulle vara bättre med 2sek (eller kanske 1sek)fördröjning utan spegeluppfällning för frihands foto.
Re: Re: Lyssnar Pentax??
Nja, tycker nog att spegeluppfällning kan vara bra även på frihand. Man kan faktiskt känna kameran röra sig när man trycker av pga spegeln. (Det man känner är kanske främst spegelns återgång och i sådana fall blir det ju ingen inverkan på bilden.)
Vad det handlar om egentligen är ju att inte gruppera flera funktioner automatiskt tillsammans utan att låta användaren bestämma. Det är ju det som skall vara fördelen med en systemkamera.
Bra gjort. Hoppas de lysnar. Jag har varit lat och inte skrivit, har ju räknat med att någon annan, kanske till och med någon på Pentax måste komma på att det saknas en AF knapp på batterigreppet.... Just nu käns det som är det enda jag verkligen behöver, samt att det ju vore smidigt att kunna programmera om RAW-knappen till att vara vitbalans.
Jo sedan var det ju det där att gröna programmet inte är riktigt grönt. Jag har drabbats flera gånger av komplexiteten av att förklara att man måste fokusera på AF innan man kan ta bilden, och för att kunna fokusera måste kameran vara igång och då måste man först trycka in avtryckaren till hälften. Inte direkt en "kan du ta en bild av mig" kamera just nu...och det är väl det GRÖNT är till för.
Ja, framförallt punkt 4 har jag stört mig på och tjatat om i andra forum, alla andra har dock varit helt oförstående.
Punkt 1 kan också vara bra, 2,3 är dock inget jag saknat, ännu.
Peter, du har alltså slagit av autofokus på halvtryck? Med det påslaget, vilket är default, så kan man väl knappast misslyckas i grön mode. Bara tryck knappen i bott.
Jo men det känns ju lite omständligt att gå in i custommenyn ocgh ställa om AF, sedan ändra till grönt, låna ut kameran, och sedan ställa tillbaka igen.... För att använda klarspråk, urpuckat :) Grönt skall vara grönt och ignorera alla mina specialinställningar :)
Det undrade jag också innan jag testade för några månader sedan. Anledningen är att man får mycket bättre kontroll på när man vill att kameran skall fokusera. Kanske låter dumt, men framförallt i situationer med dåligt ljus där kameran har svårt att fokusera, vill man inte att de skall göra det för varje bild man tar utan endast då motivet flyttat sig och jag väljer att fokusera igen. Dessutom går det ju väldigt enkelt att ratta fokusen manuellt om man så önskar. Nu när jag vant mig känns det svårt att gå tillbaka och vara hindrad av att jag måste vänta på fokuseringen för varje bild. Iofs så är vi inne i den ljusa perioden nu, men kommer ändå att ha kvar det som det är nu.
Ok, jag provade själv för ett tag sedan och tyckte bara att det var opraktiskt, men i mörker eller vid andra fokusproblem kan jag tänka mig att det inte är så dumt.
Verkar som du har kontaktat Pentax US... :)
Tja, marknadschefen Ned Bunnell är ju ofta på Dpreview och jag vet att representanter för Pentax UK är och surfar run. Sedan finns det ju japanska forum som besöks frekvent av tekniker på Pentax. Huruvida Pentax verkligen lyssnar på just *dig*, det är en annan fråga. De lyssnar och tar till sig det som de flesta verkar tycka.
Spegeluppfällning med skakreduceringen... Intressant idé, men givetivs helt meningslöst. Alltså, skakreduceringssystemet kompenserar ju för avtrycket du gör när du trycker ner slutaren. Det är just den grejjen som gör Pentax system unikt jämfört med Sonys/Konica-Minolta. Pentax kan alltså kompensera för roterande rörelse, som händer när man trycker ner slutaravtrycket. Sony/Konica-Minoltas system kompenserar bara för upp och ner.
Spegeluppfällning används för att utsläcka kamerans egna vibrationer från spegeluppfällningen när kameran är monterad på ett stabilt underlag. Dessa vibrationer är mycket mindre än de vibrationer som skakreduceringssystemet kompenserar för. Dvs, spegeluppfällning gör ingen nytta ihop med skakreduceringen, eftersom skakreduceringen kan ej kompensera så att det blir lika vibrationsfritt som med kameran placerad på ett stabilt stativ. Du har skakningar även med skakreeduceringen och dessa skakningar är större än vibrationerna från spegeln, även om de är mycket mindre än om du körde utan skakreducering. Så spegeluppfällning har ingen effekt eftersom skakreduceringen ej reducerar skakningar till absolut stillastående.
Hälsar
R
