D70 batteri i D200?
gost
Har granskat de olika batterierna och det förefaller som om det vore möjligt att fräsa ur en liten bit av D70 batteriet (Där det mittersta bläcket sitter på D200 batteriet), då borde det passa i D200:an, eller?
Tror ni det fungerar? Någon som vill testa på ett gammalt D70 batteri? Skulle vara rätt intressant att veta.
Hittade själv svaret på min fråga
"There is a third contact on the EN-EL3e for the battery's SWB (single wire bus). This is used in conjunction with the battery's negative terminal to allow digital information to flow between the battery and camera. The D200 was programmed to not work if there was no SWB connection, even if the voltage was there. If you want to get an EN-EL3 to work in the D200, dont try modifying the battery, try decrypting and fixing the firmware.
Which is nearly impossible BTW. Good luck :-D "
