Canon 5d mark III klara 4K med Magic Lantern även "fullres" i 7.4fps
jonas18z
Roligt att ML-teamet att släppa detta på första april.
1920×960 @ 50p (both 1:1 crop and full-frame – 3×3 pixel binning)
1920×800 @ 60p (same as above)
1920×1080 @ 45p and 48p (3×3 binning)
1920×1920 @ 24p (1:1 square crop)
3072×1920 @ 24p (1:1 crop)
3840×1600 @ 24p (1:1 crop)
4096×2560 @ 12.5p (1:1 crop)
4096×1440 @ 25p (1:1 crop)
Full-resolution LiveView: 5796×3870 at 7.4 fps (128ms rolling shutter)
Den sista är väldigt intressant för fotografering.
Right now, you can take the mlv_lite module with pre-recording and half-shutter trigger: at 10 bits per pixel, you get 5 frames pre-recorded, and saved to card as soon as you touch the half-shutter button. Or, you can capture one frame for each half-shutter press, with negative shutter lag! (since the captured frame will always be pre-recorded).
And if a burst at 7.4 fps is not enough, you may also look at the 4K modes (12-15 fps).
Ej stabilt än men rätt otroligt att de lyckats.
http://www.eoshd.com/2017/04/super-35mm-4k-comes-canon-5d-mark-iii-new-magic-lantern-module-real/
Och jag som köpte en 5D Mark IV idag ... helt i onödan ;)
Så om 5 år kanske de kan få ur 6K ur 5D Mark IV ...
