Bilder från Hi matic GF
Danlo
Finns det någon som har erfarenhet av kameran Minolta Hi-matic GF? Köpte precis en för 30 spänn på loppis, den är jättefin :D
Lins: Minolta lens 38mm 1:4
Hur bra är linsen ? Vinjetterar den mycket? Jag hoppas ju på lite Lomokänsla då den är så enkel, endast tre bländare och en fast slutartid..
Någon som kan nåt om denna kamera?
Det är en mycket enkel kamera, men jag tror inte du får särskilt mycket "lomokänsla".
The name of the camera implies the Hi-Matic G (an older similar camera) -- but with a flash. And it many ways it is just that. It's a small, black, plastic camera -- very light and pocketable. There is a pop-up flash built in on the front. Film advance is by a serrated wheel set in the back -- not the normal advance lever. A hand strap is on the right side. Filter threads are 46mm.
The lens is a Minolta 38mm (f4.0), but it is not marked ROKKOR. Tthe lack of the Rokkor name dates it to the1980s. This is unlike the lens in other contemporary Hi-Matics, AF and S(various versions), which featured a 38mm f2.8 lens. Three apertures are available -- wide open (f4.0) and then approximately f8.0 and f16.0 -- each using weather icons. These are Waterhouse stops, that is, holes in a switchable plate that is inserted in the light path. The perfectly circular aperture is ideal. Focusing is by scale, from head-and-shoulders (about 1m) to infinity using four icons. The leaf shutter offers one speed, apparently about 1/100 second.
There is a built in CDS meter, but there are only two speed settings -- ISO 100/21° and 400/27°. The meter does not set the aperture, as one might assume. It simply indicates if the current aperture setting is correct. There is an under-exposure warning, but none for over-exposure. Given this simple exposure system, it was obviously meant to be used by unknowledgeable people using print film, and allowing the film latitude to take care of any problems. The camera operates electronically with 2AA batteries, which power the flash and meter. It also can be used without batteries in a limited way, keeping in mind the particulars given above.
http://members.aol.com/manualminolta/himatgf.htm
    8.7 KB · Visningar: 137
