Yashica Electro 35 MC?
- Trådstartare Jimpawa
Bostromi
Jimpawa
Jo där har kikat, hittar dock inget om 35MC tyvärr, kan kanske vara pga att det inte är en mätsökare?
Utan använder sig av fokusområde, har fått fram att objektivet ska vara rätt skarpt, och det ser ut så på: http://www.flickr.com/search/?q=Yashica+Electro+35+MC
Verkar hur som helst vara en trevlig liten kamera, i ganska kompakt format, så får nog försöka skaffa fram en eller ett par rullar film och testa
Bostromi
Står inte speciellt mycket of MC men det finns där i alla fall.
http://yashica-guy.com/document/snapshot.html
"The Yashica compact MC & ME do not have a split image rangefinder, so you need to estimate the distance from the camera to the subject yourself. These cameras are referred to as ‘Zone Focus’. As you can see in the images kindly made available by John Cliffe in England, focus is facilitated by the addition of Icons representing the most typical viewing situations.
Matters are helped along by the employment of a short focal length lens which increases the depth of field considerably. The 38mm Yashinon ƒ2.8 lens gets excellent reviews for sharpness and colour correction.
In general, lenses with a focal length this short, introduce undesirable distortions in the perspective of close subjects. Although not nearly as serious as a true wide angle or fisheye lens, this is not the camera of choice for taking portraits.
By locating the light sensor within the lens group, filter factors are automatically compensated for. Another advantage as we have pointed out with models employing this feature.... you are unlikely to be able to keep shooting unless you take the lens cap off. The lower part of the lens group has a window, showing the selected ASA speed.
When the use of Flash is indicated by lighting conditions, the camera is moved from AUTO to the Guide Number for the flash in use"
Annars är det väl inte så mycket att säga om den. Fungerar som de andra electrokamerorna. Minus mätsökare . Sätt i ett batteri och testa en rulle.
Har själv två MC för säkerhets skull, en svart och en silver. Har blivit lite trötta med åldern, elektroniken hänger inte riktigt med. Slutartiderna styrs mer av slumpen.
Jimpawa
Hmm det hade missat, tack så mycket!
Rent elektroniskt verkar den funka riktigt bra, som jag kan höra tar tiderna rätt:
Får försöka skaffa fram nån rulle billig film och testa helt enkelt
Vart mest lite förvånad när det fanns så lite att hitta om den.
Känns dock som ett bra köp och trevligt litet tillskott i kamerafamiljen
zingiber
Det gula är en symbol med ett litet fönster och ett svart fält. Ska väl vara "inomhus" och "natt".
aha - så de tänkta motiven är krabbor, snorkråkor och fönster!
klockrent! sånna exponeringsprogram vill jag ha på min digitalare...
