Nya Sigma-objektiv med bildstabilisator
Här kommer en snabböversättning (webb) till engelska av artiklen från sidan som nämts ovan:
"With the occasion of Photokina, Sigma reveals four new objectives which did not finish making salivate amateurs and professionals. The time when Sigma teased the large marks with cheap objectives is quite completed: from now on, the turbulent Japanese optician privileges the chart of the innovation, as the four innovations testify some which have been just announced:
- zoom trans-standard 28-70 mm f/2,8-4 HSM: will be available as of October 2002 in mountings Canon, Nikon D, Minolta D, Pentax AF and sigma.
- Telezoom 80-400 mm f/4,5-5,6 EX OS "Optical Stabilizer". Yes, you well read... "80-400 stalibilized!!! A true innovation, with two modes of stabilizations: Mode 1 (H + V) for the static subjects, mode 2 (H only) for the follow-up of subjects moving. Like the other objectives with ultrasonic motorization HSM, it authorizes the permanent final improvement of the point without disengaging of AF.
- zoom 120-300mm F2,8 EX IF HSM is a luminous ultra telezoom with constant opening F2,8 with motorization HSM.
- zoom 300-800mm F5,6 EX IF HSM is an ultra telezoom with constant opening of F5,6 with motorization HSM. These three new zooms EX will be compatible Canon, Nikon and... Sigma, which means that, contrary to certain rumours, the numerical reflex camera of the mark is far from being buried.
In parallel, Sigma announces two flashs:
- flash EF 500 DG ST, automatic flash TTL with head directional automatic zoom, intended for the cases silver and numerical reflex cameras.
- flash EF 500 SUPER DG, intended for the photography advanced with the flash with the cases reflex cameras silver and numerical (special functions of the compatible cases).
Frågorna är många t.ex.
- Är det buffel o båg?
- Om det är så, priserna på sådana objektiv som 120-300/2.8 lär bli dyra
- Photokina är om 6 dagar så då får vi se.
Ja, det surrar av rykten nu.
Ska bli spännande att se om Sigmas objektiv ovan, Canon 1Ds mm verkligen kommer eller om det bara är drömmar och påhitt.
Malm skrev:
http://www.dpreview.com/news/0209/02093003sigmalenses.asp nån som har koll på vad ett Sigma APO 300 - 800 mm F5.6 EX IF HSM kommer gå på? :p
Jag har varit i kontakt med huvudkontoret i Japan och kan bara meddela att inga priser på de nya objektiven är satta ännu. Inte heller Expert i Sverige har en aning om priserna. Men om skulle ta och ge sig på en kvalificerad gissning så..
Sigma 80-400/4.5-5.6 EX OS APO 12000:- (Nikon tar 17000:)
Sigma 120-300/2.8 EX APO HSM 18000:- (finns inget liknande på marknaden idag)
Sigma 300-800/5.6 IF APO HSM 25-30000:- (mycket svårbedömt, 800/5.6 är ju häftigt)
Dessutom får man ju ett 240-600/5.6 med en 2x extender på 120-300:at..
Vidare kan upplysas om att Bernt Didrik på Expert Sverige gissar att priserna kommer i början på nästa år.
Fler priser, denna gång från ColorFoto 10/2002:
120-300/2.8: 4000 Euro
80-400 OS: 1500 Euro
300-800/5.6: 9000 Euro
För 9000 Euro kan man väl lika gärna köpa ett 400/2.8, en 1.4x och en 2x-konverter... ;)
Nåväl.. 9000€ verkar vara tungt för ett sådant..
Likaså 4000€ för 120-300/2.8 när ett 70-200/2.8 kostar 800€..Men men..den som lever får se..
1500€ för 80-400 verkar vara hyffsat rimligt men det är ju i samma prisklass som Nikons så det känns lite tveksammt
Liten uppdatering över läget.
Hittade ett pris på Sigmas EX 120-300/2.8 hos min favorithandlare i Tyskland.
2992€ eller ca: 27500:-
Sigma EX 300-800/5.6
7494€ eller ca: 68000:-
Tyvärr inget pris på 80-400/4.5-5.6 OS ännu.
Billigare!!!
Sigma 120-300 f2,8 EX HSM kostar på B&H $1899 + 8.5% tax så det borde bli runt 18500:- Sek om man åker till NY och handlar ; )
// Alex Dawson
Fast å andra sidan så väger tex ett Nikkor 300mm f2,8 2560 gram.
Visst säkert bättre skärpa men å andra sidan ingen zoom.
Så jag vet inte om jag tycker det var såååå tungt.
Allt beror ju på vad man jämför med.
Filterstorleken var ju inte att leka med däremot, undrar vad ett polfilter av bra kvalité kostar?
Priset vad ju inte heller helt avskräckande...
/Svante
Jeppe skrev:
Jämföra ett 70-200/4 med ett 120-300/2,8 zoom ???
Ska det vara äpplen eller päron på Julbordet? ;)
Jag vet att det inte är en rättvis jämföresle. Menar bara att om ett 120-300/2,8 är så tungt så nöjer jag mig med vad jag har. Dom täcker ju trots allt ungefär samma behov.
