135 2.8 STF har ett filter för att ge bättre bokeh och ta bort bländarformade mönster.
Som jag förstår det har objektivet 2 bländare, en med 9 blad och en med 10, på grund av filtret så förlorar man 1.5 bländarsteg, och får en effektiv bländare 4.5, med skärpedjupet av bländare 2.8.
Det är dessutom ett MF-objektiv.
David Kilpatrick på en Minolta maillista:
To: <[email protected]>
From: David Kilpatrick <iconmags at btconnect dot com>
Date: Thu, 14 Feb 2002 11:37:31 +0000
Subject: Re: AW: [Minolta] Re: Just received the 135/2.8 STF lens
It has a centre graduated filter in the middle of the lens next to the iris. Clear in the middle, darker to the edges. It is not a coated or dyed filter, but is actually shaped (negative) lens element. By making the lens element out of grey tinted glass, the thicker edges of the minus lens are denser than the thin middle bit. Simple idea, quite brilliant. It means that wide apertures have a graded edge to the iris shape, instead of a clean circle, but small apertures are not affected and there is less speed loss. It looks a bit like a 'centre filter' as sold for Super Angulon wide angle lenses.
I supposed someone must have ordered a pair of -3 dioptre Ray Bans and noticed that they are clearer in the centre than at the edge!
Minolta owns a huge number of really strange and exotic patents, including many acquired or bought from inventors and photographers. A guy in New Zealand sold them an entire greyscale zone system metering patent for viewfinder displays, not yet used.
The STF might be their own, it might be one they were offered. It is certainly unique. I am not sure if the whole graded effect is achieved by glass thickness though (this is what they told me).
David Kilpatrick
Du kan alltså inte stänga av filtret, utan får alltid en effektiv ljusstyrka av 4.5, fast det är 2.8 egentligen.
135 2.8 är ett äldre objektiv, men jag tror inte man kan säga att den ersattes av STF-objektivet eftersom de är så olika.
Annan Minoltaoptik lämplig för porträtt i det omfånget är:
100/2
100/2.8 Soft, med softningsfilter i 3 olika nivåer och en skarp inställning (filtrena gör hela bilden lite oskarp, inte bara bakgrunden.).
100/2.8 Macro 1:1 (Finns i 3 versioner, Orginal, RS och (D))
Sen finns det även, om man går utanför omfånget lite, Minolta 85 1.4 G (i 3 eller 4 versioner), som ska vara skarp som f*n, nästan så att den blir olämplig för porträtt för att den är FÖR skarp.
Edit: stafvel
