jonas18z
https://www.adorama.com/fplfx300ptb.html
Tror ni den kommer till Sverige?
Second Curtain Sync
300ws in the most well thought out design
Ready for shot after shot with 0.01 – 1 Second Recycle Time
Reliable and brilliant Flashpoint R2 2.4GHz Radio System
Auto-Sensing and Switching Radio Slave Modes for Canon, Sony, Nikon, Fuji, Pentax and Panasonic/Olympus M4/3
328 feet / 100 meter R2 signal reception range
Rear port interchangeable 14.4V / 2600mAh Lithium-ion Battery
Manual Flash over 9 Stops: 1/256 – 1/1 Output (1/3rd or 1/10th Increments)
Flash Modes – TTL / M / Multie
5 Groups keep the pace and the peace – A / B / C / D / E
32 Channels protect the isolation of the signal
High Speed Sync to 1/8000th second
Advanced IGBT circuitry for stable and precise flash duration
Last Shot Auto Memory Function
FEC / FEB – 1/3rd Increments (±3 Stops)
FEL (Flash Exposure Lock)
S1 Standard & S2 ‘Smart’ Optical Slave Modes
Professional balanced Color Temperature at 5600øK ± 200øK
Stable Color Mode narrows to variable down to ±75øK
Bi-Color LED Modelling Light (3000øK ~ 6000øK) (M / Prop)
Native Godox Modifier Mount
Quiet Fan Cooled mechanism
Large Dot Matrix LCD Display
An Abundance of Custom Functions
Type C USB Port for Firmware Upgrades
3.5mm Sync Port for manual sync connection
Sleek measurements 7.5×3.8×3.4in / 19.0×9.8×8.7cm
Light Weight Heavyweight at just over 3.0lb / 1.4kg with Battery
