JensEkberg
När jag printar photorag papper 188gsm i min 3800 så får jag en "grå hinna" på mina utskrifter. som ser fullständigt för jävlig ut. Epsons Matta papper blir bra. Ilford Gallerie Smooth likaså. 308gsm pappret blir bättre men fortfarande inte bra.
Färghantering sköts av PS3, PS4 eller LR2 inte av skrivaren. Pappersprofil är nedladdad från tillverkaren. Skärmen är kalbrerad osv. Jag tycker iofs att profilen är för grå redan i PS.
kör osx 10.5.5 PS3/PS4 LR2
Vet ju att man kan få fantastiska utskrifter på detta papper.
Idéer el tips någon?
Var hittar man batch nr på pappret ?
Läste oroväckande följande på photo.net
"David Parker, May 05, 2007; 12:25 p.m.
Hi Scott, Good news! Simon Waller at Hahnemuehle UK came good and sent me a roll of Photo Rag to test. I cut 2 sheets to A2 size, 1 with the weave parallel to the long side (as with the cut sheets of A3) and the other perpendicular. My expectation was that the perpendicular weaved image (the same as the cut A2 sheets) would produce a muddy result. To my surprise and consternation both images were perfect! Without changing my settings I then put in a sheet from my original A2 pack, fully expecting some trickster diety to suddenly rub his hands with glee and make this paper batch work perfectly, because I'd forgotten to hire in the right number of virgins to dance naked around my lawn on the last full moon. But no! The old paper batch was still producing dreadful prints. I concluded that this particular batch of paper must be the culprit; 134752-A to be exact. Simon Waller then placed an enquiry with Hahnemeuhle Germany and it turns out that this batch had already been identified as being faulty, apparently the hot weather complicated the coating process, curiously, conditions that also cause problems with the manufacture of 19th Century printing-out papers! The company had thought that all of the paper from this batch had been recalled. Happy printing out there! Regards, David."
mvh
Jens
mvh
Jens
